When I plug a USB drive in my TV and then back in PC, it shows a problem.
Prsnr
Hello,
every time when I plug a USB drive(no matter empty of full) in my PUS6554 TV and then back in my PC, it shows that there is a problem with the drive
I tried to format the drive and then plug it in my PS4 and then back to PC - no problems
This only happens when plugging it into the TV.
I'm scared to plug in my 1TB external HDD(it has a lot of info) so I can watch DVD movies which are bigger than my USB stick.
Any suggestions?
AVtest
Hello,
Any suggestions?
Are you using safe remove option before unplugging?
if anything I am not sure why you bother with USB? does Saphi not support any network explorers? DLNA?
Prsnr
You sure there is no apps trying to write to drive? reformat drive?
I formatted 5 times. Every time when I plug the drive into the TV, the TV creates 2 files:
data.db and db.info (the third file is added by me)
AVtest
can you not open them files? as example using notepad or database viewer?
Prsnr
Actually it shows this dialog box just by plugging->unplugging the USB drive.
I just checked again - no files written.
AVtest
I just formatted the drive in NTFS and the message no longer shows up.
Well could be then firmware bug in tv in relation to fat32. Its a bit sad that philips tv's don't support exfat yet. At least you got it working :smashin:
grahamlthompson
The TV is setting up the drive to be able to record programmes. Once set up you can't use the drive on a PC without reformatting.
AVtest
It should not do that automatically. Usually would require user confirmation. Any drives plugged in should be in external storage mode first.
grahamlthompson
Maybe not. But the data.db file is most likely the recordings database file.
