When i play a dvd on my 360 the screen size is 4:3?
deadred
Whats going on, i used to be able to watch them ok but i just tried watching a dvd and the size was 4:3 i haven't changed any settings :confused:
deadred
Nah its not that either, i have just changed my display from 720p to 480p and the screen went down from 16:9 to 4:3 which it never used to do before :confused: :confused:
eyeballKid
Don't really use the 360 as a dvd player, but it could just be that the WSS info isn't transmitted in 480p but is in 720p (my dvd player does this) so your TV thinks it's a 4:3 picture. And why switch down from 720p to 480p anyway? Look at the movie - are people tall and stretched (if so you'll need to manually switch aspect ratio) or is it the correct proportions just with bars on all sides (in which case ensure widescreen not 4:3 letterbox on the 360 TV settings).
deadred
You sir are a genius :D
I had to switch the WSS on :suicide: , thats what i get for buying a new telly and forgetting to change it
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
