when comparing scart cables what should i look out for?
Discussion in 'Cables & Switches' started by 7 of 9, Jan 12, 2004.
  1. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    sorry if ive put this in the wrong place i didnt know were to put it
    when comparing scart cables what should i look out for and take note of on dvds.
    thanx from 7 of 9
  2. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    What do you mean? In terms of picture quality?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    GOOD PICTURE Quality,
    Sorry in=know it very obvious but that what your after i guess. one menus with white boxes look for movement in the boxes, shimmer flicker etc can all be due to noise a good scart (in fact any cable ) will minimise noise visible on screen.
    Really you want the R,G & B signals to have individual sheilding, Buy one you think is good, then making sure you can return it before paying then a cheaper one and a really cheap one and swap em around and see what you think.
  4. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    thank you for all and any help.
    geezer i mean quality of contast, colour, noise, sharpness etc
    what should i look for and at, and take note of when i am comparing scart cables with dvd
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    SKY menu/EPG is a good one i had no idea of the difference untill i swapped the DVD player (Good scart) with the standard Vivanco one on the sky box! Big difference.
  6. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    Yes a good scart lead with sky works wonders. At the moment i use QED squarts on my dvd and sky they arnt cheap but very effective
  7. bobbypunk
    bobbypunk
    VDH Thescart 1.5m currently £85 RRP £135
    Look out for lack of interferance
    Sharpness
    colour seperation
    and if needed then good sound.
    if you can't pay £85 then go with the previous advice Sqarts are good value even @ £50
