Wheeled TV Trolley
Capnbob
Hope this is in the right section !?
I’m looking for recommendations for a wheeled TV trolley.
It’s for my rugby club who are looking to extend capacity under Covid restrictions with a marquee and want the ability to manoeuvre a 75” tv in and out. Is there anything out there that has more robust castors than the black plastic ones
Joe Fernand
Outstanding Member
AVForums Sponsor
TV in a marquee - can be pretty challenging unless you have full blackout within the Marquee.
Trolley - Unicol ‘K’ base every time, ensure at least two of the wheels are lockable.
Joe
noiseboy72
I don't think the Unicol K Base is stable enough for a 75", you might need a Titan stand for that. AXIA TITAN STANDS & TROLLEYS RANGE They are taller and more stable.
You need to think about the height of any door frames, as a 75" TV on a tall stand will not fit through them. A lower stand allows for this, but it makes visibility of the bottom of the screen quite tricky.
You can get electric stands that overcome this, but they cost a small fortune!
Joe Fernand
Outstanding Member
AVForums Sponsor
K may be OK as long as below 70Kg - though as you say you may have to go heavier and yes to checking door heights, vision lines, flat floor etc
More smaller Displays dotted around the marquee would be my choice.
Joe
noiseboy72
I don't think the K Base is stable enough with that size of screen. There's a good chance it will topple over rather too easily as the legs really aren't that spread out. I've used them for up to 60" TVs and they feel a bit marginal with those. The screens are mounted a fair way towards the rear and the can topple with a slight shove.
Capnbob
Cheers everyone, will give these a look.
It’s more of overspill from the main clubhouse so doesn’t need to be a perfect set
Joe Fernand
Outstanding Member
AVForums Sponsor
It’s def a big screen to move around/ensure it is safe in a marquee - worth having the discussion with Unicol if you already have the screen.
Joe
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
