whatsapp Only phone with no browser installed (not just option to remove )?
Farhanc007
Hello my question is are there any WhatsApp only mobile phones ?
As I want to message, call, video call, etc.
Also take photos, calendar, notes, calculator, alarm radio, etc.
But don’t want any internet.
I look forward to hearing the thoughts here.
Yours
Farhan
dts197
Why would there ever be a mobile phone designed to just use WhatsApp? And you do realise WhatsApp cannot be used without the internet?
Just buy any cheap phone and don't download any other apps. Simple.
Upvote 0
oneman
WhatsApp doesn't work without internet, even Wi-Fi is OK. If are trying to simplify the phone for say somebody elderly then what I have done in the past is change the launcher, there are some locked down ones designed for simple use. You can get a few icons.
There are some options here,
Also some providers exclude WhatsApp in their allowance so you don't need a high data amount, not sure if that includes excluding video calls.
Upvote 0
Farhanc007
What I mean is No internet browser installed(not just option to remove ). But allowance for WhatsApp ,and other features
Yours
Farhan
Upvote 0
Timalay
You may want to look at one of Nokia's smart feature phones, with KaiOS. They are like the Nokia phones of yore, but you can still get some of the core apps (WhatApp included). Depending on your budget, but the Nokia 6300 4G can be picked up for £54.99 direct from Nokia at the moment.
Upvote 0
Everything Goes
Definitely a back to basics phone but for some reason the Farhan wants something without a web browser. I don't think such a thing exists in modern times that also supports WhatsApp.
Upvote 0
Steven
Senior Moderator
Uninstall or disable the apps you do not wish to use 😎
Upvote 0
Timalay
To be fair, I think the web browser on KaiOS is very basic. I'm no expert on the matter, but I would imagine an OS like KaiOS doesn't use data in the background as much as Android and iOS does. Maybe that's what OP is worrying about.
Upvote 0
finbaar
There is no phone available to buy that has an application for WhatsApp (hawk spit) installed ready to use and no internet browser installed.
I'm guessing Farhanc007 wants such a phone for someone else to use. The only way to achive this would be to install two users on an Android device with the second user with restricted access and only allow them the use of WhatsApp. There are many ways of achieving this and I would suggest searching for the latest information. I have done something similar to this this previously but it was a number of years ago and things have moved on considerably.
Upvote 0
Timalay
Except for KaiOS as I said earlier.
Upvote 0
Dave X
KaiOS has an internet browser.
https://medium.com/design-at-kai/what-you-didnt-know-about-kaios-browser
Upvote 0
Timalay
That point I am trying to make, that KaiOS might not always be running data in the background like Android and iOS can. Maybe that's why the OP doesn't want the interenet.
Upvote 0
prking
KaiOS uses data in the background for email, messaging, calendar, contacts, account backup etc.
Upvote 0
oneman
That would be WhatsApp text only. And still uses data.
Upvote 0
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
