Whats Wrong with this pls?
Discussion in 'Plasma TVs' started by sdbull, Dec 26, 2004.
  1. sdbull
    sdbull
    I have just connected a Pioneer EMR D65 DVD to a Pioneer PDP 433 PE Plasma with RGB connectors. When I have switched the DVD settings to Progressive scan the picture is black and white. I have changed the settings on the TV to RGB input and the DVD output to rgb but no luck. Is my Plasma a prog scan model or is it something else I've done. Thanks
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Progressive scan uses component video, not RGB. RGB and component are subtley different.
  3. Ross_R
    Ross_R
    Folloiwng up on Nick's post, try using component instead of RGB. Personally, on my Pioneer plasma, I prefer component over RGB (but I've since switched to HDMI...)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well i assume you mean Panasonic DMR-E65 DVD recorder..... and you cant output Progressive via RGB, only component as stated above and answer me this...What has the better DE-interlcaer system a £2-300 DVD-R or a £3.5K Plasma TV????? so which DE-Interlcaer do you want to use TV orDVD-R??? I would stick with interlaced RGB or YUV
