What's wrong with my new Sky+
Discussion in 'Sky Digital TV Forum' started by SilverJDM, Oct 5, 2004.
  1. SilverJDM
    SilverJDM
    Aug 23, 2004
    337
    28
    Bracknell, Berkshire
    +38
    When I try to watch a programme that I have recorded, I get pictures but no sound, so I have to
    1. press backup
    2. select the recording again
    3. press select
    4. press select again (as per normal)
    & hey presto I now have picture & sound
    Anybody know what the problem is ??? :lease:
  2. Ian182
    Ian182
    Oct 15, 2002
    901
    46
    Leeds, West Yorkshire.
    +99
    Are you connecting SKY+ to an external Amp, using an optical lead ?
    If so, you might just need to go into the "Optical Out" setting and change it to Dolby Digital. (its not set to that by default).
    Worth a try anyway............
    Ian.
  3. SilverJDM
    SilverJDM
    Aug 23, 2004
    337
    28
    +38
    Thanks for your reply Ian, No I'm not using the optical lead yet... any other suggestions anybody ?????
  4. garyalton
    garyalton
    Hi, I'm totally new to this forum (about to post my own problem thread tho!) so I may be talking absolute tosh...
    I had a similar problem when I hooked up a Recordable DVD to my TV (with both this and the Sky+ box using Scart leads). It seems that the RDVD scart connection overrides the Sky+ one so to get sound I need to either turn off the RDVD or hit the 'TV' button on its remote (essentially doing the same thing).
    So, any other Scart cables over-riding your Sky+ box?
    Gaz
