whats wrong with it?
Discussion in 'Projectors, Screens & Video Processors' started by auctionpm, Jul 5, 2005.
  1. auctionpm
    auctionpm
    hi all.....
    whats wrong with my projector......?
    i was wondering if anybody with a more technical brain than mine knows whats wrong !!
    its a toshiba TLP 260, and the problem is that everything displayed has a red tinge to it, also it seems to have a ' thumb print ' of blue in the center of the display......
    i will be gratefull for any help
    regards
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
    Unfortunately the problem you describe sounds like heat damage to the LCD panels. This can be fixed by replacing the panels, however this is usually uneconomical to do. Unfortunately, you may need to invest in a new projector.
