What's this?
Discussion in 'General Chat' started by a l e x, Jun 9, 2015.
  1. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,700
    All knowing ones of AVF... What's this?! We moved house not long ago and just ignore it really. It's near to the phone socket and obviously something to do with a phone but what?!!
    Also... The old owners decided to add a phone socket upstairs. They've basically added an extension to the main phone socket in the hall way and then tacked the wire over doors etc and outside then up the side of the house. Can I just cut the bloody wire? It's wired into the master phone socket. Loads of tiny little wires... Can I just cut the extension or will I need to unwire it in the socket?!
    Thanks.
  2. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,700
    Re the second part of my question... The extension cable just goes into the bottom of the master socket - pic attached. Can I simply cut the wires from the extension close to the connection or do I need to remove completely?
    Thanks!
  3. BB3Lions
    BB3Lions
    Apr 24, 2009
    14,716
    3
    +6,617
    Just disconnect the extension pair.
  4. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,700
    Didn't realise they'd just pull out. Extension sorted, looks so much better without cable everywhere.
    Now... What's the weird box thing...?!
  5. phillyd1981
    phillyd1981
    Dec 10, 2006
    2,577
    +1,489
    Looks like a some pass through box can you take the front off and look inside
  6. BB3Lions
    BB3Lions
    Apr 24, 2009
    14,716
    3
    +6,617
    Could be an old home alarm dialling system
  7. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    Arrggghhh I've seen these, sure it's a restricter, I think that when it's connected you can't pick up a second handset and listen in.
    or could be a call restricter ie block international or premium numbers.
    I think :confused:
  8. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,296
    +7,412
    Looks a bit like the interface that used to sit in the phone line when I had NTL dialup as an ISP. IIRC, it routed phone calls through NTL's network rather BT's without having to dial a prefix first.
  9. aVdub
    aVdub
    May 27, 2010
    9,630
    9
    5
    167
    59°55'07.7"N 81°43'16.5"E
    +14,704
    Is it not the old fashioned first box that comes off of the mains BT connection that allows a phone to be plugged into.
  10. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,700
    We don't have BT lines here so wondering if it was something to do with that. It's on the side of the stairs, not really near the master socket.
    I'm not even sure if it is wired into anything externally, can't open it up. It's got what looks like a power adaptor plug too.
    Strange.
  11. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,700
    So... I've plugged the phone line into this box and my phone into it... Without dealing anything I get a Scottish woman saying "Sorry, the number you have dialled is not in service. Please try again".
    It's obviously trying to dial something straight away!
