whats this rms output about
Discussion in 'AV Receivers & Amplifiers' started by gipo, Jan 13, 2004.
  1. gipo
    gipo
    Dec 22, 2003
    70
    11
    Sligo
    My receiver has a min rms output of 65w @ 20Hz to 20kHz 0.06% THD,8ohm.
    But it also says 80w @1khz, 0.7% THD,4ohm.
    Whats the difference?
    Can I select either of them or are they just tests?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    They're specs at different output levels into different loads....the first specifies the receiver's output into an 8ohm load,and the frequency band across which it will output that power,together with the distortion it produces,in this case,quite reasonable figures.
    The next set of values you've given is the output into a 4ohm load,and as you can see,despite halving the load,the output rises only a very small amount,and the distortion rises quite markedly,indicating that the receiver doesnt cope well with low impedance loads.
    Which you pay attention to will depend a lot on what load your speakers are...i.e.4 or 8 ohm.
    Distortion figures are often a waste of time,as some beautiful sounding valve amps have awful measured distortion figures,and there have been plenty of wonderful measuring but awful sounding amps also....use your ears on that one,but certainly pay some attention to power output and load tolerance,remembering that very few amps have the capacity to keep doubling their output as the load halves(which in theory is what a perfect amp should be able to do).
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    They are just tests, but the values also relate to the speakers you are going to use. See Alexs2' explanation.
