What's this "Digital Interface" on my Grundig GDS3000?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by crawf1982, Oct 20, 2003.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    173
    East Midlands, UK
    +7
    Just got a Grundig GDS-3000 Sky digibox. On the back there is a removeable panel over which is written "digital interface". I removed the panel and had a look inside. There is a space and a series of pins which look like they are for attaching a ribbon cable to.
    Does anybody know what this is for? There are no clues in the manual. Could it be for adding an SDI output to the box?
    Very interested in your thoughts on the matter.
    Cheers,
    DAve
  2. PhilipVass
    PhilipVass
    Not being funny but are you on about the batteries slot?
  3. wandgrudd
    wandgrudd
    Dec 16, 2002
    172
    Nottinghamshire
    +6
    its not used yet my be used some day but sky have never made any thing to fit in it/ use it. all sky boxs have it but non use it.
  4. eMonk
    eMonk
    Isn't this thing basically a PCMCIA slot as used in other satellite systems for a CAM?
