What's this D1/D2 digital output on Jap DVD players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cybersoga, Jan 27, 2003.
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    [​IMG]
    "The D terminal which can enjoy connection and high picture quality quickly with cable 1.
    You connect, with the television of D3/D4 terminal attaching such as BS digital broadcast corresponding television, you equip the D2 output terminal which makes the high picture quality only of the progressive indicate. "
    Is it a bit like DVI? and more importantly, are we going to see it appear on our DVD players?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    BS is HDTV broadcast. I think the D1/D2 is equal or at least similar to DVI (consumer version of the connection instead of the PC type?).
    Seen a few plasmas here on demo with HDTV material (aka "BS high"), looks GREAT!
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,340
    Windsor
    +1,026
    they vary. I think D1 is straight interlaced video signal, nearest equivalent is SCART. D2 is progressive scan SD. I think D3 is the first HD format and I'm not sure about D4.
