What's this brass pipe coming out of kitchen wall outside
p1tse
blue max
Its your boiler 'overflow'.
Or more precisely, it's a visual indication that there is a problem.
p1tse
Yeah maybe not brass, copper type? Dunno lol
p1tse
Strange as boiler isn't there but is a couple of metres away at a guess
Piscauk
Maybe from a previous site of boiler? Looks too low down for a combi as most are placed up high....
IanW1977
Looks like it's from an old gas heater capped off gas pipe. We have similar in our kitchen and utility room
p1tse
The house is only about 10-12 years old
Not sure if boiler has been changed
Could it be overflow from 1st floor as the opposite side to this inside are pipe work from upstairs ensuite location
Trollslayer
That corrosion after 10-12 years needs checked out.
There would be an internal leak coming out there.
SteveCritten
I think it's also condensate overflow from the boiler mine runs under the floor about 3.5m and is similar diameter.
Piscauk
Also, if it were the incoming water main it would be one stinky, thirsty household (take a second look at the picture ;))
p1tse
I should say I can move the pipe up so its not into the ground
Steroc
Judging from the manhole next to it, surely that's just your incoming water mains?
Does your incoming water main come from a manhole?
Where is your gas meter in relation to this pipe and the boiler. Could it be the gas feed from meter to boiler as it looks like a 22mm pipe? Boiler overflows (if that's the correct name) are generally 15mm. Very badly and probably illegally done if so?
EDIT: Forget what I've just said. Didn't see this post
p4ult
Shouldn't the condensate pipe from a boiler flow straight into a drain or the soil stack?
I didn't think they were allowed to discharge into the open?
If it is from a boiler, it probably is the pipe from the blow off valve.
D
Deleted member 45086
It will be your PRV pipe. Pressure Relief Valve pipe off your combi or pressurised boiler.
Not ideally positioned, but it's ok there. Do you have a new pipe similar to this from the new boiler?
Carl
p1tse
Newish into the house
But I believe house is only about 10-12 year old
Original boiler might be still in use which is on the same wall but about 3-4 metres away at guess
p1tse
Not sure what the man hole cover is for actually
Latest News
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
Movies Podcast: 26th September 2022
  • By Phil Hinton
  • Published
AV Podcast: 26th September 2022
  • By Phil Hinton
  • Published
REL Acoustics announces new Serie HT subwoofer trio
  • By Ian Collen
  • Published
Marantz set to launch new Cinema Series of AV receivers
  • By Ian Collen
  • Published
