Whats the sky wireless transmitter & receiver called?
Discussion in 'Sky Digital TV Forum' started by RHCP, Mar 11, 2006.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Wanting to watch sky upstairs, but don't want to pay for multiroom!
    Do they work well?
    Can i use the sky remote upstairs to change the channel?
    Someone told me they sell them in tesco's for £20, Can i really buy it that cheap?
    Please help! I havn't a clue :)
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Magic eye?
  3. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    hhhmmm! don't think so!
    Is that wireless?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    There is no "Sky" wireless transmitter. There's lots of wireless transmitters capable of being connected to Sky, with varying degrees of success. As with most things in life, you get what you pay for. Try Argos or Maplin - they do them.
  5. neiljones
    neiljones
    May 29, 2002
    469
    northwest
    +13
    You need
    Co -ax or satellite cable from rf connection of Sky Box to distribution box-depending how many lines out you require determines the size of the box- I have four
    You then need a magic eye connected to the co ax cable upstairs neasr to the tv.
    Once connected you can change channel with the Sky remote.
    You can get "0u2" boxes to accommodate up to eight tv.
    Maplin sell them-cheaper than the Sky recommended ones
    NJ:lesson:
  6. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    I'm sure the OP is referring to a wireless sender of some sorts NOT magic eye as he already posted.
  7. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    http://www.maplin.co.uk/Home.aspx .then search for video sender
    Is this what you mean????if it is it is better to spend as much as you can.I tried the cheaper one and it was very poor,Changed it for a different(more expensive) model and it is brilliant, worth getting an extra remote as well as this will work with it:smashin:
  8. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    That link just sends you to the Maplin home page, doesn't show the model you're referring to.
  9. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    i know, You need to do a search on video sender,Green box uper right side, i cannot get the direct link to work...but will keep trying for you
  10. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
  11. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    OK!
    I've just connected my tv via co-ax to the second output on my sky box.
    I'm now a bit stuck!
    The tv downstairs is connected by scart as well, so when i swith the sky box on it automatically comes on as AV1.
    Because it's not connected by scart upstairs how do i get sky to come through.
    Do i need to retune my tv?
    It won't be on an AV channel will it because it's not connected by scart, or am i just being stupid??
    HELP :)
  12. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    See my answer to this in the separate thread you started asking the same question.
    Chris Muriel, Manchester
