What's the score with HD?
Discussion in 'Plasma TVs Forum' started by Binkysdad, Aug 9, 2005.
  1. Binkysdad
    Binkysdad
    Feb 3, 2005
    119
    From reading some of the Threads, I can see there are some real knowledgeable people out there.. I hope you can help me in the same way as you have helped others.
    Also, I'm not a techy so please keep any answers simple so I can understand.
    I am looking into upgrading my TV to a plasma and it appears the Panasonic 7series, gets everyones vote.
    I'm seeing a lot on here about HD and when selecting the Panasonic TH-42PWD7UY in the shop selection on this site, it says it's HD TV ready. Is this correct?
    I am still also working on convincing the wife, that Plasmas are the way to go. Only problem is, everytime we walk into a shop. The picture quality never appears to great on a plasma, compared to a normal TV. I have Sky+ at home, so am making a big assumption that the digital signal will look crystal clear once it is setup?
    I know HD stands for High Deifinition and can make a educated guess as to what it means. But from a non techy view, what is the real difference between this, a digital signal or a play back of a DVD?
  2. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    The PWD7 is not HD ready.
    Most plasmas on display in ordinary TV shops are very poorly set up and tend to be connected less than optimally to poor source devices. When set up properly the good plasmas will match the picture quality of all but the very most expensive conventional TVs. The Sky digital signal isn't a very high quality source but it will give a good picture when done properly.
    High Definition TV is capable of delivering a better picture than DVD (and DVD should be better than Sky). There is more information in the broadcast signal which gives a clearer, more accurate picture when displayed on a high definition panel.
    If ultimate picture quality is your goal then the PWD7 is not for you but many people on here find that it is good enough for now and it displays standard definition TV and DVDs very nicely.
  3. Binkysdad
    Binkysdad
    Feb 3, 2005
    119
    So what is the real big difference between a Plasma and a standard TV?
  4. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    Size.When did you last see a 42" telly,never mind 50" and above.
  5. Binkysdad
    Binkysdad
    Feb 3, 2005
    119
    I didn't think of it like that...
  6. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    And your average crt may look a little out of place hanging on a wall :)
