Whats the purpose of.....
Discussion in 'General TV Discussions Forum' started by hulkhead, Jul 4, 2002.
  1. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    Whats the purpose of a 'comb filter'? Can someone please explain. Is it a permanently switch on feature or can it be turned off / on? I have a sony 32fq75. thanks.
  2. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Hope this is of some help
    Paul
  3. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    The comb filter achieves the clearer separation by subtracting the color signal taken from adjacent lines in the picture, so to 'comb' out the color from the luminance. A regular TV uses a notch filter, that simply cancels the frequency at which the color signal is found. That leaves some smearing, and limits the overall resolution.
    Comb filters come in a variety of types, for instance a 2-line comb filter will subtract the color signal taken from each previous line, a 3-line comb filter will subtract the sum of the previous and subsequent lines, and a 3D comb filter will adapt its processing depending on motion. They can also be analog or digital with various pro's and con's to either. 3D comb filters are digital.
    A comb filter permits both a reduction in interference between color and luminance, as well as a slightly higher resolution. In practice I think it is quite subtle, you are likely to see the most difference in a test card but not as much in typical video.
    You usually cannot turn the comb filter off, but it will not activate in S-video or RGB signals since it is not applicable there. It will only be functional with composite signals (from an external device or the off-air RF feed).
  4. stranger
    stranger
    zacabeb, has the tosh 36zp18p got a comb filter?
  5. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Digital Comb Filter? Yes.
  6. stranger
    stranger
