What's the point unless it's PAL prog?
Discussion in 'Projectors, Screens & Video Processors' started by ste_d73, Jan 2, 2005.
  1. ste_d73
    ste_d73
    Dec 13, 2004
    26
    Hi all..bit of a newbie, just wanna clear something up before I help my bro buy an all in one system.
    My brother has a plasma with component inputs. These will accept prog scan. However I have recently learnt that getting a DVD player with prog scan output is not good enough. It needs to be "PAL progressive". There only seems to be a few PAL progressive all in ones out there,amongst them the JVCTHS8.
    My question is this. All the DVD players out there that offer progressive scan,not PAL progressive, can still be hooked up to a plasma's component inputs, but does it give a good quality picture if it is not a PAL progressive machine?
    If not I really don't understand the point of a standard prog scan output on a DVD player meant for the UK region 2 market. Ie if it won't give prog scan on a PAL disc what's the point in having it?
    I hope I've made myself clear. Hope someone can help me understand better.
    Cheers.... :smashin:
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Component feed without progressive in most cases is still excellent.A lot does depend on the dvd players ability to produce a good interlaced signal.Toshiba machines are very good at this.I have a toshiba340e and sometimes struggle to see any difference between the two scanning formats.
  3. ste_d73
    ste_d73
    Dec 13, 2004
    26
    So am I right to say that ideally my bro should get a DVD player with PAL prog output, but a regular component output will still provide superior images to a RGB scart connection..?
    Your help is much appreciated. :D
  4. patrik_f
    patrik_f
    Nov 19, 2004
    164
    +4
    Your TV/panel may have better deinterlacing than the DVD player!
    I just bought a Toshiba SD-241E DVD player (£55!) and its progressive PAL is not as good as my Toshiba LCDs built-in deinterlacer. (Progressive gives a slightly sharper result, but some flicker in areas of the picture.)
    However the 241Es component output is still very, very good in interlaced form, giving the panel a good material to deinterlace! (Note: The SCART mustn't be connected simultaneously with the component leads with this player! It affects the picture dramatically.)
    Your other question: A film sourced DVD has interlaced fields (half frames) that come from the same frame of the film. So deinterlacing will actually restore a single full resolution frame (so it is progressive!).
    For excellent technical information see:
    http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.html
  5. ste_d73
    ste_d73
    Dec 13, 2004
    26
    thanks mate much appreciated..
