What's the point of FFDShow resizing?
Discussion in 'Desktop & Laptop Computers Forum' started by mikearv, Dec 5, 2004.
  1. mikearv
    mikearv
    I've heard alot of people who say they set FFDShow to resize in Lanzos to resolutions higher than their display can handle to acheieve higher PQ.
    What exactly is the point of this when your DVD software & video card just resizes that back down again to at most, your max display resolution.
    Surely this is like taking a jpeg image that started life at 640x480, resizing it to 1024x768 then resizing it again to 800x600? If you have a graphics program and you compare a jpeg that's gone from 640x480->1024x768->800x600 to the same image that's gone 640x480->800x600 you will see the results are totally identical, so surely the same applies to video?
    Why use up all of that CPU power to perform FFDshow resize?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    The basic idea is that FFDSHOW is better at scaling than the graphics card and its' driver. Bearing in mind that up-sizing means filling in the gaps then there are a large number of ways of doing that, some produce better results than others, and FFDSHOW's Lanczos implementation is better than most.
    Now, I have to admit I'm not sure of the theory that says resize larger, except that it's probably the case that it's easier to resize to, say, twice the size since computers like multiples of 2 :) .. the algorithms I guess may work better than having to resize to a non-multiple and introduce fewer artifacts though I don't have the equipment capable of showing that.
    Down-sizing is a lot easier than up-sizing and tends to introduce far fewer artifacts so letting the graphics card down-size doesn't really impact PQ.
    At least, that's how I understand it. :)
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Problem I have with the downsize technique is that I'm pretty sure most graphics cards use a bicubic for both upsize (which is fine) and downsize which is not : ideally you want to use a sinc type filter for downsizing. I've yet to figure out if graphics cards bother to employ different filtering for each process.
    Also you don't always employ the sharpest filter you can as often a sharper interpolation leaves you with more aliasing and beating than a softer "lesser" filter.
  4. mikearv
    mikearv
    Sure but in the end the graphics card is scaling, something you cannot avoid?
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Yes, but the issue is what that process involves in terms of altering the image.
    Downsizing at its' simplest is simple pixel elimination whereas up-sizing means 'creating' pixels from adjacent ones, by definition this is adding information not present and thus artificial. It's how seamlessly the added pixels are integrated into the image that determines the resulting picture quality.
    Say you're up-sizing by a factor of 2, the easiest way is simply to do pixel doubling, which will look dreadful .. down-sizing by a factor of 2 at its' simplest means deleting every other pixel, which will be nowhere nearly as ugly.
    Mr. D:
    you may well be right, however many people do seem to re-size to 1440x960 so there must be something that makes it useful.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I'd dispute that to be honest. Some packages concatenate their image transform operators so a res up followed by a res down will counteract each other perfectly mathematically unless you actually render out each stage. (Shake is one package that does this ) Quite a few don't bother to retain the the information lost at each step so the differences from package to package are quite marked.
    I don't think the processes employed in getting a video res image to a higher display res will concatenate through ffdshow (certainly looking at processor overhead they don't).
    And of those packages that don't concatenate often whilst they use a decent default filter for upsizing they don't bother to change the filter for downsizing. (This is what actually worries me about the whole oversampling theory when applied to domestic PCs)
    And I could also argue that a video image should be completely linearised prior to any process that involves pixel value interpolation then reconverted back to video colourspace prior to display ( or left in linear and a suitable display LUT used to view it)
  7. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Just when you thought you were beginning to understand :clown:
