What's the normal method of cable entry/exit to /from a wall?
Discussion in 'Home Cinema Building DIY' started by AVmaster, Jan 19, 2005.
  1. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    So far i've cut the channels in my wall for wall mounting my plasma and i've sunken a single mains backing box into where the plasma will sit. The only thing I can think of to keep the entry and exit holes to the wall clean is to fit a blanking plate with a 2 inch hole drilled out.
    Ideas anyone?
  2. John
    John
    Dec 13, 2002
    10,931
    +2,619
    That'll do the job . :thumbsup:
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Sounds good to me. If you want to make it look really good you could put a rubber grommet around the cable which fits into the hole so that it's sealed up tightly. :)
  4. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
    I have the cables to my projector coming through the ceiling by a drilled blanking plate. I didn't fit a gromet but sanded the edge of the hole smooth and stuffed black fabric into the hole around the cable and it looks very neat.
  5. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    I made a gromet out of plumbing parts, you can see photos in the CRT PJ section under the CRT install thread :)
  6. Ward
    Ward
    I used office desk gromets sourced from a local stationary wholesaler. Look the part and allow easy access.
