whats the need in a 2 way sub cable
Discussion in 'AV Receivers & Amplifiers' started by sonic1988, Feb 12, 2014.
  1. sonic1988
    sonic1988
    Sep 20, 2012
    14
    on deli zensor 5s sub? and whats the perpose pros and cons i know on old style sub i currantley own is 1 lead to amp? in red or white socket
  2. dante01
    dante01
    Mar 5, 2009
    46,102
    +11,048
    The output from the receiver to a sub is mono so both left and right connections are not required because frequencies that are being redirected away from your other speakers are all mixed down into one channel by the receiver. Its usually suggested by subwoofer manufacturers to use the left RCA input, but you should check within the manual. The correct input to use is sometimes labelled "LFE". The two inputs are there in order that the sub can be used in conjunction with more conventional stereo setups that lack bass management.
