Whats the minimum viewing distance advised for RPTV
Discussion in 'Televisions' started by Bristol Pete, Jan 24, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Whats the minimum distance advised for Rear Projection TV, say about a 44" screen?
    I am about 3.5 metres, straight on. Will I get the benefit or is that too close to enjoy??
    Thanks.
    CB.
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Any RP owners sitting closer than 3.5 metres ???
    Thanks,
    CB.
  3. juboy
    juboy
    Suggested viewing distance from CRT and RP TVs is normally between 4 to 5 times the diameter of the screen.
    As you've mixed up inches/feet and metres in your post I can't be arsed to work out whether you've got it right or wrong :D
  4. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    Between 4.5 and 5.5 meters for a 44" screen.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Me.
    About 3 metres, 40" RP.
    Although the 'guest seat' is 2 metres and at an angle.
    No probs on either.
  6. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Depends really.
    If you're watching Condorman then I suggest about 3.5 miles back from the TV, otherwise you should be OK ;)
  7. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Great thanks Kevo,
    I pressume that the picture is great from your view, you dont see it being made up so to speak?
  8. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Yes, it is the 'sweet spot' for both pic & sound.
    Although sometimes I get the 'guest seat' when the nephews & nieces are round (like last night!), still a good view though.
  9. raymen
    raymen
    Nov 7, 2002
    128
    2
    netherlands
    +4
