whats the difference?
Discussion in 'General TV Discussions Forum' started by IGADHIA, Jun 17, 2002.
  1. IGADHIA
    IGADHIA
    i was thinking of Panasonic TH42PWD4
    but there is like a BX and a 4D and a TNR version and stuff as well...
    what is the difference between these?
    thanks
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,173
    The Borders
    +3,379
    IGADHIA
    Hope this helps:
    Panasonic TH-42PW4B - 42" panel with silver bezel and RCA phono plugs on the RGB/Component video input.
    Panasonic TH-42PW4BSYS (or TNR) as above with external TV tuner.
    Panasonic TH-42PWD4BX - 42" panel with charcoal bezel and video card slot. Normally supplied with a BNC terminal board though can also be supplied or upgraded at a later date to the DVI terminal board. The BX suffix denotes a UK spec display which now includes a one year on-site with loan replacement warranty and a revised S-Video input circuit.
    Panasonic TH-42PWD4EX - Tech spec as above. The EX suffix denotes a Euro spec display which only includes a one year return to base warranty and no revised S-Video input circuit.
    Panasonic TU-PTA300B - external tuner which can be purchased as a stand alone unit with any Panasonic model.
    Best regards
    Joe
  3. IGADHIA
    IGADHIA
    ahh...
    so I am thinking of using the display as a DVD/tv/xbox thing as well as somehing to connect my mac to. I should be looking for a BX model right?
