Whats the difference?
Discussion in 'LCD & LED LCD TVs' started by deadred, Feb 8, 2005.
  1. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Between a DVI-I cable and a DVI-D cable, i'm wanting to connect my laptop to my LC26GA4E but don't know which cable to buy?
    Also does anyone know where to get a decent one?
    cheers
  2. imh
    imh
    DVI-I cables can carry both Digital and analogue signals, DVI-D can only carry digital.
    As your PC can probably output a digital signal your shuold be ok with a DVI-D cable, though a DVI-I would also work as it will fit the Sharp and almost certainly the PC...
  3. ajp558
    ajp558
    Apr 18, 2003
    125
    Fleet, Hampshire
    +8
    deadred
    I just bought one of these Belkin Pro DVI Dual Link 3m cables (£12.94 inc VAT but not p&P) to connect my PC (Nvidia FX5200) to my new Acer AL2671W LCD with DVI input.
    BelkinProDVICable
    Cable seems solid & well made. Picture quality is amazing compared to VGA which is just good but noticeably not as good.
    AJP
  4. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Thanks for the info, how do i find out if i can use the dvi-d cable? My laptop is a Benq Joybook 8100, i've looked in the manual and can't see anything
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Deadred,
    Be sure you get the correct connetion. If your PC has a DVI-I port then you can get a DVI-I or DVI-D cable but if the PC has a DVI-D port a DVI-I cable will not fit.
    Take a look on here for the pin configurations....
    http://www.lindy.com/uk/tips/uk/Digital_Monitor_Connections_Explained_/index.php
    Note the 4 extra pins on the left on a DVI-I male connector. Now take a look at the DVI-D female and see there are no pin holes for the 4 pins.
    Richie.
  6. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Now to confuse matters more i've noticed my laptop only has a vga output :confused: for a second monitor
  7. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
  8. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Cheers Rich, i've just ordered those, i'll let you know how i get on
  9. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    I've found that my laptop will not support the native resolution (1366x768), even with an unregistered version of Powerstrip. Apparently if you register Powerstrip you can get a driver for it though.
    Richie.
