whats the difference in these 2 processors
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by 90210, Jun 8, 2005.
  1. 90210
    90210
    Hi, Thanks everyone for all the help so far but now i have another question! What is the difference performance wise in the Athlon 64 3200 and the 3500? I want to have 1 mb memory on both of them. Will i notice any diff between the 2? I am just getting to grips with what specs i need and think i have come up with one i like but there are 2 choices and i cant have the 3500 on the one i fancy the best.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    You'll probably get a more definate answer to this in the HTPC forum, but AFAIK the numbers relate to the clock speeds of the processors. Therefore the 3500 will be slightly faster. As for wheather it will make much difference for NLE, well I don't think it will be that noticeable TBH. Both processors are fairly powerful, especially compared to my old P4 1.8GHz :( , and therefore should fly through any rendering with 1Gb of RAM to help :smashin:
    Mark.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Beware ! Athlon processor numbers do not directly indicate their clock speeds. The 3500 is actually clocked at 2.25GHz.
