What's the difference between a Sandisk MSPro Duo and the Gaming Version?
Discussion in 'General Video Gaming Chat' started by Tobias, Mar 28, 2005.
  1. Tobias
    Tobias
    Jun 17, 2003
    Leatherhead, Surrey
    +6
  2. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    They are both exactly the same, i am not sure why the brought out the gaming but i have got a standard and it works perfect!
  3. dr_loss
    dr_loss
    the gaming one is prettier and appeals more to the style conscious psp owner
    also i think it is slightly smaller as some people have reported that the standard one can be a bit a tight fit, so get the cheaper one!
    ________________________________
    www.ballofodd.co.uk - everything PSP
  4. Tobias
    Tobias
    Jun 17, 2003
    Leatherhead, Surrey
    +6
    The cheaper one is the standard one.
  5. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,759
    On AVForums
    +569
    marketing ploy to make more cash, 'gaming' sounds better than standard. There will be no difference in speed at all.
  6. Tobias
    Tobias
    Jun 17, 2003
    Leatherhead, Surrey
    +6
    I realise that there won't be any difference in speed, I'm just wondering whether there will be any difference in size, however slight.
  7. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,759
    On AVForums
    +569
    i would hope not tobias, they are both duo's, and would be silly in my book to change the size/shape to run the risk of them not fitting, although i cant answer for sure.
  8. Digitised
    Digitised
    Oct 11, 2004
    177
    +13
    Actually there are different speeds,
    i havent seen much info on this yet since i havent done any extensive searches. But i know that 2gb sticks have slow transfer rates, so it isnt very good for quickly uploading data. There was a rumour too that when using customised display settings (technical alterations to use different resolutions to what sony pre-installed) the data isnt fast enough to actually play movies back.
    Again i havent got exact details but i know the 2gb isnt worth buying yet due to its slow performance. Apperently sonys is going to be fast.
