Whats the cheapest progresive scan player in the uk
Discussion in 'Blu-ray & DVD Players & Recorders' started by haujobbz, Jun 15, 2003.
  1. haujobbz
    haujobbz
    Jun 9, 2003
    1,903
    UK
    +90
    Someone said you can buy multi region progressive scan players made by compacks for 49.99 at safeways stores :eek:
    Im gonna have to check if this is true:zonked: :zonked:
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    I'm not sure what the cheapest progressive scan dvd player in the UK is, but I do know that in America the cheaper prog. scan players had crude de-interlacing chips that lacked vital features such as 3/2 pulldown detection, and therefore didn't really offer the main benefits of progressive scan.
    I'm not familiar with any of these low cost units in the UK, but I think it would be safe to say that they wouldn't offer the same level of performance that would be available from a better quality player.
  3. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    The Compacks appears to be nearly identical to the Cambridge Audo DVD55 that Richer Sounds sells. I have the Compacks model and its very good. I really can't fault it so far. I especially like the remote control. Its actually made by Sampo I believe.
  4. one_jedi
    one_jedi
    Where can you get this compacks from and how much is it? Is it worth it if you don't have a progressive scan tv?
  5. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    It comes from Safeway, and costs £49. It's PAL and NTSC progressive, region hackable with play .JPG,MP3 and MPG discs and stuff.
    It's dead fast, has no visible layer change and is silent. It's great for the money ;)
    The only question is how long they will last :D
    -- Jon
  6. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    If it is the same as the Cambrigde Audio DVD55, the prog-scan image is very poor. If you need prog-scan, and have a big telly / plasma / projector, avoid this player.
    The interlaced image is excellent tho - pin sharp and nice colours. But in P-scan it's blurred with lots of ghosting
  7. one_jedi
    one_jedi
    is it a compack 5000 or a different model? does it output RGB? I heard it might not or it's not stated in the menu's?
  8. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Re: one_jedi
    Compacks DVD5000 it is.
    It outputs RGB via SCART, it also has s-video, component and composite outputs.
    Co-axial and optical digital outputs, and anlogue outputs for the DD5.1 decoder.
    Re: Prog scan image issues, works fine on my AE300 but there are reports of problems in the DVDforums 'bargain' thread when used with the AE100 and the Z1 :(
    -- Jon
  9. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    Does this model output progressive RGB like a couple of the Arcams? (Choose RGB for output then preess the PROG button to flick between on the Compacks remote). Someone with a plasma would need to confirm this I expect. Would this be RGBS (with sync on composite)?
    It also has a built in DD and Pro Logic II decoder which is great!
  10. one_jedi
    one_jedi
    what about the compact DVD AB-6820, anyone know anything about this?
  11. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    I tried the Compack with my AE100, it offers poor progressive scan for pal and NTSC discs, the de-interlacer seems to remove jaggies and shimmering, but there was bad ghosting on interlaced and progressive scan, I also sufferedjuddering with NTSC discs.
    You get what you pay for :( I am going to wait for a decent progressive pal player from maybe Panasonic or Denon (faroudja de-interlacer), which are pretty much the same in the States, and get good test reviews.
  12. jeje
    jeje
    Apr 8, 2003
    174
    belfast
    +3
    just got the compacks 5000 and I have to say that it is killing my old sony s735, was gonna buy the new sony 930, but that one will do just fine for a while, don't have P scan but on a rgb scart the image is good.
    now need to find out the region hack.
  13. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    jeje
    Click here
  14. jeje
    jeje
    Apr 8, 2003
    174
    belfast
    +3
    thanks timh !!!!! I'm truly happy with that player and for 50 quids !
  15. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    The juddering you speak of is only because you had left the player on pal only mode in the menu's. The player when set to multi gives a pal image with region2 dvds and ntsc with region 1 etc. There is no juddering unless wrongly set which is the same for most dvd players. I've not come across any bad ghosting. The main problem I had was grain which was removed when I stopped using the supplied scart cable. I have a AE100 projector and find this dvd player quite superb. I really can't fault it. I don't think anyone's claiming it has best picture out there but what hifi gave the dvd57 4/5 for picture and I'm pretty sure the compacks is the same as the dvd57, dvd55 and Compacks DVD500 are all basically the same player except the CA dvd57 has dvd audio built in. The fact remains that most of us that have bought the Compacks player are very pleased with it. It may not have quite as good a picture as the Toshiba 330 but then what has?
  16. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    bonzobanana
    Glad to here someone has had success with the AE100 and the Compack, I was really hoping for cheap progressive pal with this player, but not so, the ghosting was fairly obvious to me, but I also had a problem with picture breakup with interlaced.
    Maybe I didn't try NTSC for R1 discs, I just lost interest after seeing the ghosting :(
  17. yoghurt
    yoghurt
    Jan 13, 2003
    567
    +20
    I currently watch DVD's on my Xbox and am happy with the quality.
    Will there be a noticeble improvement in picture quality with the Compacks?
  18. yoghurt
    yoghurt
    Jan 13, 2003
    567
    +20
    If someone could answer my query I would be grateful as there are not many Compacks left at my local store.
    Thank you
    Yoghurt:hiya:
  19. Winnie
    Winnie
    Mar 12, 2001
    212
    Enfield
    +4
    Excuse my ignorance. But this Compacks DVD5000 player. How do you tell it's Pal/NTSC Progressive? There is no mention in the on-line spec or the manual.
    Also can you switch between Prog & interlaced. If so how (via setup menu) ?
    Paul
  20. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    From my experience the Compack isn't worth going for, some have had success with projectors, but like me and others there is a problem with ghosting with progressive scan.
    Winnie
    There is no info for progressive scan on the website, but you can tell if it is outputting progressive by the menu on your projector, it should show 480p for NTSc and 625p or 576p for pal.
    Yes you can switch between interlaced and progressive.
  21. jeje
    jeje
    Apr 8, 2003
    174
    belfast
    +3
    Hi yoghurt, what don't you go to the shop, buy it for 50 quids then if you are not happy you can still bring it back to safeway ?
  22. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    I too would like to know if it's better then my Xbox. I have a chipped machine running DVDx2 software with progressive patch though component video cables and the pictures none too shabby.
  23. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    cyberheater
    Are you using a projector or plasma with your Xbox? Whats this DVDx2 software with progressive patch, I have never heard of it.
    Go try the Compack, you could always take it back like i did.
  24. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    TimH:
    * Am running thru a Panny AE100.
    * DVDx2 is a software DVD player for Xbox which allows you to play DVD's without the dongle and remote. You have to have a chipped machine to run it.
    Someone recently wrote a patch that allowed progressive scan output which is stunning.
    PM me if you want it.
  25. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Does anyone know if this machine is still available. I went to my local safeway yesterday (admittidly not a big store) and they did not have them.
  26. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Thanks for the offer :) But I don't have an xbox :(
    I was just wondering how it was done.
    If you want to know how good the xbox is at progressive scan just spin Star Trek Insurrection, the intro panning the village shows jaggies and shimmering, look at the low stone wall and the roof tiles, it should look bad in interlaced but with a good progressive player it should be none existent.
  27. haujobbz
    haujobbz
    Jun 9, 2003
    1,903
    UK
    +90
    I bought a compacks dvd for 49.00 the other day in s.wales they only had 2 left, i was impressed with the performance for 49.00:eek:
  28. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Well, if anyones interested. The DVD playback from my chipped Xbox running DVD-x2 with progressive patch is much better then the Compacks 5000.
    The Xbox is higher resolution and no ghosting effects.
    The Compacks is going back!
  29. clayts450
    clayts450
    Jun 25, 2001
    562
    2
    Nottingham
    +51
    There is a section devoted to the Compacks unit here.
    In addition, some folk are reporting that their player is VCR friendly, whilst others are not - please, if you own one, complete our survey here.
  30. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    cyberheater
    Ok, You got my attention :) So where could I get a chipped Xbox from? Also where can I get DVD-X2 with progressive patch? I take it that the chipped console meens you can play NTSC and Pal software.
    Do you get 480p for NTSC and 625P (576p) for pal progressive on your AE100?
    Thanks for any help :)
