Whats the biggest screen size I should use with my Sim2 DMF?
Discussion in 'Projectors, Screens & Video Processors' started by cameronl, Sep 2, 2004.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there all, I'll be building a home cinema room next year and I wanted to know what is the biggest screen size I should use with my Sim2 DMF bearing in mind the light output.
    I'll get the best gain screen I can - probably something like 1.3 and the room will be light controlled.
    I currently have a 5 foot screen in my lounge and that works very well for brightness for movies, sports and games excluding the odd dark movie like 'last of the mohicans'.
    I was thinking a 7 foot screen would work well but do you think i would get away with an 8 foot screen bearing in mind that i don't want it to be any darker than in currently is. I must add though that my current room is painted white, is 95 percent light controlled and that I use an average quality owl screen.
    thanks for your time.
    CaM
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    CaM,
    A 7ft or 8ft 1.3 gain screen would be fine with your DMF.
    I have seen them set up in light controlled rooms on 3m screens with good results.
    If you have the choice I would consider painting the walls/ceiling grey (18% reflectance) and have a dark coloured carpet too. It makes a big difference to picture quality.
    Jeff :rtfm:
  3. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    thanks for that Jeff, my Sim2 is a great projector and I can't wait to get it projecting onto a bigger screen. :)
    CaM
