What's the big deal with a EF50mm f/1.8 ll Lens? (genuine quesion)
Discussion in 'Photography Forums' started by playthefilm, Mar 20, 2006.
  1. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    What's the big deal with a EF50mm f/1.8 ll Lens? From what I have read, it seems that this is a great lens for taking portraits whilst blurring the background. Is that so? And presumably it's no good for taking pictures of objects far away...? Is it just fixed to one length (ie no zoom etc).
    Thanks.
    (still to buy my 350d :( )
  2. midtones
    midtones
    Fixed prime yes, good value for money, there's a ton of links just wack it into google :)
    K.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Fixed 50mm = 80mm on a 350D, better in low light than the kit lens. Aproaches 'L' quality if you get a good one...cheap worthwhile lens for your bag........:D
  4. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    ............and i've just posted two pictures in the sharing thread, just had it, just messing :D
    It's not just for close up's either :)
  5. Temujin
    Temujin
    Jan 17, 2005
    88
    +3
    Whats the best deal for a 50mm right now?
  6. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    £74.99 delivered, PM me for details...:D
    Don't forget you'll want this too..........
  7. Temujin
    Temujin
    Jan 17, 2005
    88
    +3
    You sure thats the cheapest? ABC does it for £73, and I'm sure there are cheaper elsewhere...
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,361
    2
    4
    137
    Garstang, Lancs
    +1,632
    How much is a lens hood for them?
  9. Zone
    Zone
    Jun 24, 2001
    6,851
    Barnsley
    +2,632
    £17 approx, probably get it cheaper if you shop around, look for ES-62 AD Lens Hood.
  10. kez
    kez
    Jan 18, 2002
    8,387
    Leeds, West Yorkshire
    +1,374
    try here, if you want to make your own lens hoods.
    they work very well :)
