whats the better buy?
Discussion in 'Plasma TVs Forum' started by tony2311, Dec 27, 2006.
  1. tony2311
    tony2311
    May 20, 2006
    LG 50PC1DA Flat Panel TV £1279
    panasonic TH42PX60PED £850
    panasonic TH50PX60PED £1500
    is 8" really worth £650?
  2. robin78
    robin78
    Jan 11, 2005
    477
    28
    +49
    Depends of the size of your living room.
  3. David1943
    David1943
    Buy the biggest screen you can afford. Plasmas soon look much smaller when you get used to them.
    David :)
  4. tony2311
    tony2311
    May 20, 2006
    i got a 3 year old lg 42" plasma screen it looks massive for the first week then it was normal, i suspect this will happen to the 50" screen aswell, So is it worth while upgrade to the same size but better picture, or pay over £650/£429 for an extra 8"?
  5. David1943
    David1943
    Having advised you to get the biggest you can afford, I must concede that you should also take into account what feeds you intend using and your viewing distance.
    David :)
  6. Timmy C
    Timmy C
    Oct 10, 2003
    5,612
    +561
    Would you say that if it were purely for watching tv rather than movies? I just ordered a 37" but could of had a 42" for less than £100 extra. The thing is I have a projector that I will always use for movies on dvd so the plasma is purely for watching stuff on Sky and playing xbox games. I don't have movie or sports channels or hi-def and after hours of changing my mind I went for the smaller one. Do you think I may regret my decision as it's not too late to change my order?
  7. Searcher2
    Searcher2
    Nov 18, 2003
    1,447
    48
    Blackburn
    +92
    For the sake of £100 I would go for the 42". It depends on viewing distance but mine looks great at 10ft on SD stuff. I wold say I could maybe stand bigger too.
