Consoles: PS2 Xbox and a Gamecube. LCD Monitor inputs - One scart, svideo and composite(vid/l and r phonos). Any ideas whats the best way to connect all three to achieve best picture quality. If this can be done with/without modding. Cheers Ps Currently playing RES 4
from those connections I would suggest RGB scart on all consoles & a switch box. check out audiovisualonline.co.uk for scart leads for about a fiver, and a switcher for £20 (these are the ones I used, great picture!). If it doesn't work out for you, not much has been lost.
