Whats The Best Way To Connect Sky+ To Plasma Please ?
Discussion in 'Plasma TVs Forum' started by eatonluke, Jan 7, 2005.
  1. eatonluke
    eatonluke
    Jan 2, 2005
    59
    Hi could someone tell me the best way to connect sky+ to plasma, also dvd to plasma
    CHEERS DARREN
  2. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    Depends what plasma you have but I connect both sky and dvd via RGB scart. I would use component if I had a dvd that output it. If you go upmarket then you can connect some dvds via digital means, hdmi etc.
    You can buy sky boxes modified to output sdi but they are expensive.
  3. eatonluke
    eatonluke
    Jan 2, 2005
    59
    cheers bud, is that a scart lead that then goes to rgb or not
  4. eatonluke
    eatonluke
    Jan 2, 2005
    59
    also bud is that better than just a scart lead from from sky+ to tv
  5. edinburgh160
    edinburgh160
    Hi, I use an IXOS rgb scart lead, and the picture quality is excellent.
    got it when local Dixons shut down half price from £80 to £40
    dvd is different. depends on what inputs you have, but the rule of thumb seems to be (from the best quality -)
    HDMI, then
    DVI, then
    RGB scart, then
    S Video,
    then (worse) composite.
    Again, people alot more experienced than me will be able to tell you, but the cables are very important, but alot depends also on the quality of your equipment as to wether the extra cable expense will be wothwhile.
    I watch SKY alot, so the better cable was definitely worth it.
  6. eatonluke
    eatonluke
    Jan 2, 2005
    59
    Thanks for that
  7. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,897
    I have mine conected sky scart to plasma VGA using a JS scart to VGA convertor.Excellent result.
  8. attach
    attach
    HDMI, then
    DVI, then
    Component, then
    RGB scart, then
    S Video,
    Think you forgot component m8 ;)
  9. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Yeah, but Sky doesnt do component...
  10. eatonluke
    eatonluke
    Jan 2, 2005
    59
    cheers for that info
  11. nealgs
    nealgs
    have ours connected
    dvd->sky->RGB2YUV->Receiver->Plasma
    Xbox->receiverYUV->Plasma
    RGB2YUV converter is a JSTech model :)
    DVD and sky are using RGB SCART passthrough to JS Tech box, which convert to component, these YUV leads are fed into YUV input on receiver, then receiver YUV out to plasma YUV in - simple :)
    Gary
  12. charker
    charker
    Aug 4, 2002
    402
    +21
  13. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have my Sky+ fed into the TV in s-video via my Yamaha amp. Very few amps do scart switching, so it has to be s-video. If you have a good quality TV properly set up, the difference between RGB and s-video is minimal. Most people who complain about Sky+ pictures do not have the correct settings, especially picture sharpness, which they invariably have wound up way too high. Sky is a "soft" picture which you can't improve with the sharpness control - all that happens is that the digital artefacts get "enhanced".
