Whats the best way to connect a Velodyne CHT-15 to a 3805?
Discussion in 'Subwoofers' started by devs, Jul 21, 2005.
  1. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    I've just today bought a Mark Grant Y-Sub cable, but I'm now getting a little unsure if I've bought the right one? There are two inputs on the back of the sub left and right and and two on the back of my denon 3805. Do I need to use both on both units?
    Has anyone else got a similar set up that could share some 3805 sub setup tips with me our is it just as easy as plus and play?
    Thanks,
    Devs. ;)
  2. Jase
    Jase
    Mar 16, 2001
    9,462
    South Coast
    +888
    The Denon only has one SW Pre-Out. The other is probably the SW input of the 7.1 External Decoder Inputs. Connect the single end of the cable into the SW Pre-Out on the Denon and the two on the other end into the Left and Right Inputs of the CHT15. Simple as that. :)
  3. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Great thanks for the reply mate!
    I thought that both of these where for the sub? Is that not the case?
    Cheers,
    Devs. ;)
    [​IMG]
  4. Jase
    Jase
    Mar 16, 2001
    9,462
    South Coast
    +888
    The top one is the Centre Channel Pre-Out. You use those other Pre-Outs if you want connect up a Power Amp. :)
  5. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Great thanks for the info mate, so I'm right in thinking that I need a Y-Sub cable 1 to 2?
    Cheers,
    Devs.
  6. Jase
    Jase
    Mar 16, 2001
    9,462
    South Coast
    +888
    Either a Y-Sub cable 1 to 2 or just a bog standard sub cable and connect to only one input on the CHT15. I'd go with the Y-Sub cable myself. :)
  7. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Great thanks for that, thats me sorted! ;)
    Get ready for the booom!
