What's the best way to archive video
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by melliott1963, Sep 15, 2003.
  1. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Here's a simple question with, I suspect, not quite so simple an answer.
    I've taken my video, copied it onto my computer and created a DVD. However, in case my 'daily use' DVD copy gets scratched and damaged in years to come, I also need to save a copy of the edited video so that a new copy can be easily created.
    Do I created a second DVD and store it in a safe place, or do I save the video back onto video tape?
    In other words, which has the greater storage life, given that I use the correct storage methods, tapes or DVD's?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    There has been a lot of discussion on DVD-R rot recently. Basically they become unreadable after a time. Cheaper disk rot quicker. This makes recordable DVD's unsuitable for safe, long term archiving.
    I would suggest that if your camcorder can do it you copy your footage back to DV tape and store carefully. Or even get a spare Hard Disk and store it on that. Disks are now very cheap and safe.
    Mark.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I'm paranoid so I'd burn image file or DVD folders to disc along with any cover artwork &/OR store these on external hard drive as well if they are that important.
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I keep all master tapes
