Whats the best type of speaker
Discussion in 'Home Cinema Speakers' started by Mwillo, Apr 19, 2002.
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    I have just purchased a marantz sr6200 and was just wondering what sort of speaker do i go for for the centre rear.
    Sorry if this is a dum question but i am new to all this..
    Mark
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Personally I´m using two monopole speakers but you could use a centre speaker if you wanted to.
    The important thing is to get the position right, try angling it down towards the listening area, it´ll take a while to find the best angle/spot but its worth it.
  3. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Cheers Jase
    does it matter if the rear centre is higher than the rear left/rights
    as the shape of my room means the only place to put it is above the french doors in the middle of the back wall.
    mark
  4. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Hi Mark
    The rear centre/s should be placed higher than the other surround speakers anyway, so you´re in luck!!
    Just make sure you get the angling down bit right, its this that makes the most difference.
    cheers
  5. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    cheers
    thats a stroke of luck.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,863
    87
    Newcastle
    +123
    Is there antwhere on the net that has more info on rear amd rear centre speaker type and position?
  7. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
  8. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    The Dolby site had some info on speaker position etc
    www.dolby.com
    Its also worth searching these forums for EX/ES speaker placement, as its been mentioned a few times over the months.
    cheers
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,863
    87
    Newcastle
    +123
    I have looked at the dolby site and they only cover 5.1 unless I am looking in the wrong place
  10. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
