Whats the best Toshiba 28" widescreen ?
Discussion in 'General TV Discussions Forum' started by Jimmi, Jul 28, 2003.
  1. Jimmi
    Jimmi
    Sep 8, 2002
    501
    28
    +29
    I went out looking at widescreen TV's today and saw two 28" WS Toshiba sets which looked really nice.
    One was 50hz and one was 100hz I think, the 50hz had a better picture in my opinion but I can't remember the model numbers of either set.
    Does anyone else know ?, and how do Toshiba CRT widescreen sets compare to other brands ?, I don't know a great deal about them to be honest.
  2. nathan_silly
    nathan_silly
    Seem OK.. skin tones seem a bit yellow though, and seem to suffer from Red Push (Red Push causes yellow skin tones I believe)
    Also some suffer from bad geometry, make sure you try out Avia DVD geometry tests in the first week. Some TV faults are not fixable in the service menu (brothers Tosh has a 1" or 2" slant on the top part of the screen- not correctable)
  3. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Nathan - a friend of mine had the slant problem aswell with his Toshiba 28Z27B...
    It was so bad, infact, that half of the writing at the bottom of the screen with Sky's EPG couldn't be read as it simply wasn't on the screen.
    I think JVC, Sony & Philips rule the roost in the 28" arena simply because their TVs are - on the whole - far less problem-prone...
    However if you get a descent Toshiba set their pictures tend to excell
  4. Jimmi
    Jimmi
    Sep 8, 2002
    501
    28
    +29
    So I guess what you're saying is the Tosh doesn't have a geomegnetic correction option ?.
