Whats the best sound system 5.1 to get for 360
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Hovvy, Jan 21, 2008.
  1. Hovvy
    Hovvy
    I have a PS3 and and xbox 360, what is the best surround sound package to get that will accomodate both systems at the same time.
  2. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    how about a budget:)
  3. Hovvy
    Hovvy
    Anything upto £350.
  4. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    you'd struggle to get a system which could take full advantage of the quality that these 2 devices can produce particularly the ps3 but you really need something with HDMI inputs on it sony do their home cinema amp 1100 about £250 rrp which might do to start with. a system like the onkyo 605 is about £400 plus speakers this would give you more but cost more. it depends on if your likely to upgrade or if this is something you plan to keep for years.
  5. Hovvy
    Hovvy
    isnt there any type of 5.1 surround with sub in a box available from somewhere that will work for both systems.
