Whats The Best Sony Vcr?
Discussion in 'Digital TV & Video Players & Recorders' started by snake II, Jul 27, 2002.
Tags:
  1. snake II
    snake II
    May 19, 2002
    349
    luton
    +5
    Hey guys any one know which is the best one, i was opting for the looks and the specs, and thought that the slv-820 would be the best option, but in terms of budject i was going for the slv-710 anyone help out
  2. Squirrel God
    Squirrel God
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    2,995
    +119
    With either of those two models, is the channel number permanently displayed?
    I have an earlier Sony VCR and it's a major annoyance that the channel number disappears from the fascia display a couple of seconds after changing channels. There are times when it's reassuring to be able to glance at the machine and check that you're recording what you think you're recording.
    A sound level indicator would be pleasant, too, to check that you're recording anything at all...
    Bert
    www.bertcoules.co.uk
  4. HMHB
    HMHB
    Nov 11, 2001
    25,456
    Nottinghamshire
    +3,759
    Are the scart connectors one above the other ? I have a problem with my panny in that they are side by side and I can't plus in 2 IXOS scart cables as one gets in the way of the other. If the sockets are one above the other there would be no problem
  5. Squirrel God
    Squirrel God
    Bert - No idea, sorry.
    JohnG - If you had clicked the link for the 710 you may just have seen this... ;)
    [​IMG]
  6. HMHB
    HMHB
    Nov 11, 2001
    25,456
    Nottinghamshire
    +3,759
    Ok mate - sorry - I clicked the one for the 810 !!!!!!!!!!!
  7. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    You might want to consider the SLV X9 if you can get one. A bit pricier but much bettter looking than the SLVE8?? and SLVE7??. It was built to match AV hifi kit so liooks the business and "according to Sony" has beeter sound and a few bells and whistles to boot.
    If I wasnt after SVHS I would have considered this to match my DVD
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Best Sony vcr is without a doubt the SL-HF950 - you can pick them up for £500 s/h if you are lucky!
  9. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Mmm, excellent choice for the budget minded, and easily purchased media as well, every corner shop sells blank beta tapes!!!!
    I can see you are a fan of beta, but surely even you have to admit that with a spare £500 a new DVD recorder would have the edge on a 2nd hand Beta player!
  10. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    But which recordable DVD format?
    I want the following
    DTTV tuner
    Bit stream record mode
    will play in a Sony DVP-S715
    As to blank tapes - I have got arount 300 - including about 20 Pro-X L500
    I was _given_ a Sony Vhs deck (something or other 715) and it is a pile of poopoo.
    Only good points being timer to scart recording
    Picture is poor much worse than Sanyo M40 and the 950 is so much better.
    Even going into rewind picture search from play takes ages - should be instant.
    Loose power for 1 second and the time has gone - 30 min on Sanyo, hour on 950.
    I tested the 950 on the following
    can record the 3 1/2 MHz test card bars
    Recorded pictures from Nokia box with one of the old pay channels are indistingushable from live (Discovery Wings was the test). (I use composite as RGB was taken up by DVD and DC) and who needs an ex Ondigital box for actually viewing - just taping.
    I think the 950 can easily be said to be the best UK Sony home vcr ever.
    We never got ED-Beta here (literally broadcast quality):( :mad: :(
  11. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,754
    Somewhere in South Yorkshire
    +4,908
    Completely true. This was the pinnacle of Sony's VCR development. Unrivalled picture and sound quality, more navigation controls and edit features than anything else and far more connection options. Would you like one? ß
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Hmm some messages missing!!!!!!!!
  13. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Just the one!:p
