Whats the best SKY box ?
Discussion in 'Sky Digital TV Forum' started by e603861, Jun 27, 2003.
  1. e603861
    e603861
    Dec 5, 2002
    7
    Im getting Sky and was wondering which is the best box/reciever at the moment .
  2. DaveP
    DaveP
    Others will probably disagree but I think the Panasonic still takes some beating. I don't think the differences are quite so noticable these days. I don't think there is such a thing as a bad one!
    DaveP
  3. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    Having just bought a new plasma tv i was hoping for a good picture from sky using JS RBG<->VGA convertor. The pq on some channels is quite poor, probably more noticable now than previously. I currently have a AMSTRAD DRX300
    Is a new sky box likely to make much difference? Are sky+ boxes worth getting based on pq rather than DD capability
    Lee
  4. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    I recently purchased a sony digibox for £150 which did not match the picture quality of my old panasonic :eek:
    Kept the panasonic (worth about £50) sold the sony on ebay :p
    The panasonics seem to be well respected by many sky engineers too :)
  5. DaveP
    DaveP
    Hi ted26, glad to hear you are still enjoying "My" Panny!;)
    DaveP
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You are probably seeing the result of low bitrate/high compression mpegII channels on SKY D. Problems with PQ which are not evident on a basic 28" 50hz CRT can become evident as the display capabilities increase.
    PQ is very subjective and a recomendation from anyone carries not guarantee that your hardware/eyes will agree.
    I haven't seen any significant difference between the PQ of the PACE SKY+ and PACE 2200 connected to my RPTV and while some people do say a certain make/model is better on their telly it's hard to quantify.
  7. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    :rotfl: davep its all mine :rotfl:
  8. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    ted
    What tv do you have, and which particular panny sky box
    Lee
  9. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    I have a panny th-42pw5 plasma fed with a 3 yr old panny digi box(cant rem model number) via a JS RBG<->VGA convertor :)
    The picture quality is good to say the screen is 42"
  10. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    Ted
    i have exactly the same set up albeit with the amstrad.
    This is the subjectiveness that starburst is on about.
    Last night watching the football on either eurosport or channel five, sorry five, when there was a general shot of the pitch, the large areas of green became blocky with jaggeded edges around the players. I tried with my old sony 28" and the poor quality was there, and noticable when watching cricket and tennis .
    Also when watching transition between white and black it looks like the picture is in 256 colours with distinct grading zones.
    Is this the best that can be expected? can anything improve on this?
    Lee
  11. DaveP
    DaveP
    You say it's an old Sony but do you have any "picture enhancement" technology turned on? You can get clashes. Try turning all digital processing off, if you can. Even try 50 Hz if your set is 100Hz switchable.
    DaveP
  12. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    The old sony is only a 50Hz set, and i don't think it has any picture enhancements, but will have a look tonight. but it is the plasma 42wd panny that i want a better picture on. i was using the sony as a reference.
    Is it worth calling out SKY, or getting some-one in to look at the quality of the sky signal? I am going to try a friends sky box to gauge improvements for myself. my question is really are these glitches expected / lived with?
    Lee
  13. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    I think u have a problem somewhere m8 as i get no blockiness on any channels even when the camera pans across the screen pretty sharpish.
    The only prob i have is that the picture is sometimes not as sharp as i would like but this is due to how it is broadcast and not my set up :)
    As u have spent so much cash already i would advise u get someone to have a look and see if your dish is aligned properly or swap your sky digi box with someone u know to see if its the box!
  14. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    I finally settled on THIS reciever. Whether it's 'the best' or not, i don't know, however it's quick and stable and works for me.
  15. charlaph
    charlaph
    May 29, 2003
    242
    Dundee
    Just for everyones information as this is a thread newcomers are likely to look at, I was given a Thomson DSi 4101 skybox with my recent installation and it's very good. Picture quality is good with an average 2/3 strength, and it's one of the fastest switching/menu navigating boxes I've ever used. Very happy with it considering it came as part of the £1 installation offer. So far in my first month it's only locked up once forcing me to turn it off and back on again, after which it's worked faultlessly.
  16. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    charlap
    It is this very same box that I am borrowing to compare with my amstrad. It should be interesting to see the difference. The guy who i am borrowing it off claims that he doesn't get a good picture, and that sometimes the analogue ariel gives better pq
    I wish i was as fortunate to get one lock-up on my amstrad. recently it has taken a miute or two just to power up. will probably get sky out to have a look anyway
    Lee
  17. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    compared the pq between the amstrad and thompson and would be lying if i said i could see a difference.
    i am going to get sky+ for sound reasons but want to improve signal quality at the same time current at around 60% for strength and 75% for quality
    Anyone have any experience with improving signal quality and strength through sky.
    Lee
