sanjuvarma
Hi all,
I’m shopping for a good short throw 1080p projector under $1000. I have purchased two right now (trying it till I can return), one is BenQ W1085ST and the other Optoma HD26 (not a short throw projector). I only have exactly 7’8” to 8’2” of distance between the projector and my screen. The BenQ is low on lumens, and I really like the brightness and contrast on the Optima HD26 (3200 Lumens). Looking to view 100" of higher screen size.
I have a week before I return both these projectors, but can you please advice on what I should be buying for the specific dimensions I have above. I would prefer anything above 3000 ANSI.
