whats the best setup
Discussion in 'Blu-ray & DVD Players & Recorders' started by ado, Jul 12, 2005.
  1. ado
    ado
    Nov 6, 2003
    192
    +6
    ive just received my viera pv500 with free dvd recorder DMRES10 but i also have a pioneer 575.
    the problem is which has the best picture output.
    as i dont have space for both and a centre speaker in the cabinet.
    so if the pioneer has the better output i will just have to see how good the speakers are on the pv500 and lose the centre speaker from the setup.
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I would say never loose the centre speaker!
    It is a proven fact that when, comparing picture quality and sound quality, in relation to detecting drop in quality (annoyance), the sound is more detectable.
    This being the case, I would recomend you keep the speaker and run the highest quality signal (RGB, CAV) from the DVD device which would allow you to do so.
    Regards,
    Gareth.
  3. ado
    ado
    Nov 6, 2003
    192
    +6
    it would be component from either source
    i might just have to splash out on Pioneer VSXC502 but thats just throwing away a good av receiver
  4. ado
    ado
    Nov 6, 2003
    192
    +6
    have splashed out and bought a slim centre speaker and the panny vcxc502
    now they all fit in :clap:
