What's the best screen position ?
Discussion in 'Projectors, Screens & Video Processors' started by Ray, Apr 10, 2005.
  1. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    I'm in the middle of building the walls to a new HC room and need to put in a mount for the centre speaker. Trouble is I haven't worked out exactly where the screen will be positioned (IN THE MIDDLE - I hear you cry!).
    I'm going to build a fixed frame 96" x 54" but need to know how far off the ground the bottom edge should be. When seated should your eye-level be 1/3 of the way up the screen or 1/2 way up the screen. What's the general consensus ?
    Unfortunately I don't have a PJ yet so can't just project and make my own mind up.
    Ray :)
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
  3. kelaD
    kelaD
    I have had a sacrifice speaker height slightly (so the tweeters are below ear height, by placing the speakers on their stands horizontally) so that the screen height is not too high. Has anyone alse had difficulty in balancing audio and visual??
  4. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    I get around ! :eek: That's good coming from you PJ ! :devil: Shouldn't you be hanging around in the DVD players forum ? :D
    I'll take a look at the link - ta
    As far as screen/speaker height I'm glad to say I've allowed 18" either side of the screen for my CD100s. Hopefully this is still far enough from the wall for them.
    Ray
  5. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Apparently, 37" from the floor to the bottom of the screen is ideal for most home cinema set ups.
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    Having the screen too high can give neck strain after prolonged viewing, which is why the 1/3rd of the way up eye-line is a good guide. It's your screen and your personal preference though. :)
    You'll find looking down more comfortable than looking up, so try not to have it too high if you can.
    Gary.
  7. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    Thanks. I think the 1/3 rd rule at eye level is a good starting point to experiment.
