Recently a three and a half year old Samsung LE32R73BD LCD TV set has started coming up with "No Signal" on the screen.
Having had an ariel guy come and check everything is aok in the house which it was.
I swapped the Samsung over with another set in the bedroom that was working perfectly to test if it was actually the TV and I confirmed my suspisions that it was.
Anyway I guess I'd better get another set but I probably won't buy another Samsung.
So the question is whats the best quality and value set under £1000 ?
I'm not sure if I should pump for an LED Backlit set or not I'd look at a 3D set but that would mean the Panasonic (as i don't want another samsung) and that is £2000 which is out of the question for me.
Size wise I'm willing to go bigger.
So what would you guys suggest?
