whats the best player for around £200 or under
Discussion in 'Blu-ray & DVD Players & Recorders' started by technovorgin, Jul 16, 2004.
  1. technovorgin
    technovorgin
    Jun 16, 2004
    233
    Leeds/Wakefield border
    i need composite out for plasma
    5.1 to go to sony amp
    multi region
    need to play backups and home made dvds
    mp3 playback
    progresive scan (pal & ntsc if poss)
    the best for panasonic th-42pwd6 if this helps i have component board only so am not bothered with how many scart sockets :thumbsup:
  2. Taz69
    Taz69
    Apr 15, 2002
    3,479
    Bristol
    +356
    Hi m8, do you mean component out for the plasma ??, I use a Marantz DV4300 with NTSC/PAL prog output, it is a very good player, nice picture to my PT AE100 pj, it was £299.99 but can be had from RS for around £119.99 now, seems a bargain to me, you may have to ring around the RS stores to find one, or you could have a look at this months What Hi-Fi for the tests on some dvd players, The TOSHIBA SD340 came out tops, for picture sound etc, and price, £79.99 :thumbsup: not had chance to look at one myself yet, but it sure came out good in the review. it has Component out etc, and from what I can tell on the mags etc, there seems to be a higher price model £99.99 with DIVX addon,
    The above players play MP3's from CDR, not found one yet that plays em from a DVDR, (that would be nice, lol) the 5.1 for your sony amp, do you mean 5.1 phono's or CO-AX/Optical out, the marantz has both co-ax and optical, not phono out, not sure about the Tosh.
    Hope this helps
    Taz
  3. technovorgin
    technovorgin
    Jun 16, 2004
    233
    yes mate it is the component to plasma from back of dvd (3 phono to 3 phono lead)
    the 5.1 into amp is phono leads (6 of them)
    but i think i have optical input into amp
    the most important thing to me is that the quality is there, theres no point in having a good plasma and an inferior picture
  4. bossc@
    [email protected]
    Dec 20, 2001
    1,172
    +273
    Check out the Pioneer thread on here. I've just swapped from an old Marantz DV4100 OSE using JS Tech RGB>VGA converter feeding a Panasonic PW5 plasma and have been extremely impressed with the image quality.
    Theres a lot of happy people just bought into the new Pioneer budget range.
    Taz - doesn't the Marantz 4300 convert NTSC to PAL60 or is it a true NTSC output?
  5. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Check out the latest H.C.C.
  6. technovorgin
    technovorgin
    Jun 16, 2004
    233
  7. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    That'll be the current issue of Home Cinema Choice magazine which tests 10 new players. The Pioneer 470 comes out top for players under £150. Hope this helps.
    Steve
  8. technovorgin
    technovorgin
    Jun 16, 2004
    233
    cheers ill get it :thumbsup:
