Whats the best pioneer av receiver?.......
Discussion in 'AV Receivers & Amplifiers' started by fecdave, Aug 1, 2005.
Tags:
  1. fecdave
    fecdave
    Mar 4, 2004
    137
    16
    for the following System
    I am just about to order a Pioneer 505 XDE Plasma
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=8888&taxonomy_id=62-63
    I will also be ordering the S VLF3 Speakers
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=5189&taxonomy_id=42-99
    and the DV668 Av DVD Player
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=6048&taxonomy_id=45-64
    What would be the best Pioneer AMP for the following system, I have seen the Pioneer VSX1015S for £375.00 at RGB Direct, would this be ideal for this set up?
    Any thoughts ideas and comments would be very much appreciated
  2. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,211
    Chelmsford
    +514
    If money is of concern go for the VSX-2014i-S if not go for either the VSX-AX5Ai-S or the daddy VSA-AX10Ai-S I own the 2014i-S and it's connected to my 868 via i-Link. I have a 7.1 system setup and it works like a dream.
  3. wannabeav
    wannabeav
    Hi, The speakers you're looking at aren't big money so may not be too much point in spending loads on the amp (unless you want to upgrade the speakers sooner and keep the amp?). Might be better off spreading the budget a little more evenly. Also, depending on budget might be worth considering other makes of amps?
  4. Asaf
    Asaf
    Jul 26, 2005
    153
    Bangkok
    +5
    FecDave,
    What did you think of the S VLF3 Speakers? I am in the market for some 5.1 speakers and wish to look at Pioneer.
    Cheers,
    Asaf
