We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Whats the best make of blank media?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GalacticaActual, Nov 1, 2005.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,135
    Galactica C.I.C.
    +357
    Ok, so got a new DVD recorder but is there any reall difference between ,say tescos own DVD-R recordable dvds ,and maxwell or TDK? or are they all pretty close to each other in reproduction of the image recorded?
    What is the favorite brand for people here?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    There are definitely different compatability & reliability levels between discs.
    Manufacturers are the important factor & some brands may change manufacturers periodically changing their reliability levels, so it is not always easy to keep tabs on.
    I have always found Maxell to be pretty good but a bit expensive as far as branded names go. Same with TDK.
  3. HMHB
    HMHB
    Nov 11, 2001
    27,611
    Nottinghamshire
    +6,551
    I've had great success with Verbatim DVD-Rs, particularly the ones using the Taiyo Yuden dye.
  4. aka_Gilo
    aka_Gilo
    Oct 19, 2005
    78
    Bristol
    I've used various Verbatim discs for a while and never had a dud so I'll be sticking with them.
  5. JethroUK
    JethroUK
    Dec 5, 2004
    1,145
    +34
    As far a quality of image there absolutely no difference between £5 TDK and 20p hoo flung dung (brown dye :) - it's digital recording
    Some machines are fussy over media tho and that pretty well determines what you buy
    they do say that cheapos dont last so long - but i have 18p ones recorded over a year and still work fine
