Whats the best looking .TS/HDTV video player for your pc ?
Discussion in 'Televisions' started by peve3, Nov 10, 2004.
  1. peve3
    peve3
    Aug 14, 2002
    436
    Hi there basically the question is in the title,
    I have tried WMP10 which looked alot better than VLC, Much sharper looking with far less blur to the edges of objects etc.
    I was just wondering what players you lot use which give the best results ?
  2. alixy007
    alixy007
    Use ZOOMPLAYER
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Check out Moonlight Elecard and Media Player Classic as well.
    Jeff :rtfm:
  4. dvdmike007
    dvdmike007
    media player 10 with the moonlight codec
  5. Kramer
    Kramer
    Zoomplayer is just a front-end/GUI, won't play didly squat without codecs - Elecard/WinDVD/WM Player etc.
    :smoke:
  6. keylion
    keylion
    Oct 13, 2002
    184
    Lancashire
    +3
    Just got TheaterTek 2. Although it does cost around £40.00, this is a massive improvement over VLC.
    KL
  7. homeagain
    homeagain
    Mar 24, 2004
    411
    Norfolk
    +9
    I agree with KL. Theatertek 2.02 puts out an incredible image with HD .ts and .tp files, VLC doesn't come close but it is free !
    Cheers, Rob. :smashin:
  8. THE_COW_IS_OK
    THE_COW_IS_OK
    Nov 11, 2004
    10
    I am using ZP with Sonic Decoder. It have great pic. Plus it was the only one to be able to play back HD Hotbird feed (24mb/s) smoothly.
  9. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    TheaterTek 2.02 for me too :)
  10. rogeralpine
    rogeralpine
    Oct 28, 2002
    565
    16
    Is there a trial period for TT2.02?
  11. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    There's no trial period AFAIK.
    IIRC I think it works something like this:
    You buy it, you try it, if you like it you activate it, if not you request a refund.
    Once you've activated it you can't get a refund.
  12. beeblebrox12
    beeblebrox12
    Zoom Player is the ultimate player for DVD and HDTV. VLC is the worst piece of multimedia software I've ever seen. Everything else goes in between.
    ZoomPlayer is the best because it gives you full control and unprecedented flexibility. Nothing else comes even close. It is true that it can't play MPEG2/TS/WMV-HD by itself - it requires you to purchase third party codecs on top of it, but this is actually an advantage. You can use different codecs for different types of media, which equates to always being able to use the best without changing the familiar, very user friendly interface.
    For HDTV I use ZoomPlayer with Cyberlink (PowerDVD 5) and Intervideo (WinDVD6) codecs.
