whats the best lnb?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mo, Sep 22, 2004.
  1. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    as the title suggests,what is the best lnb for picture quality?
  2. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,437
    Reading
    +170
    Which bird(s)?, What dish size, etc?
    An LNB with low noise (0.3 - 0.4) is the way to go but installation and dish size will also affect reception.
  3. peggle
    peggle
    Aug 29, 2004
    116
    +10
    Invacom 0.3dB probably the best value at around £30ish. Mine is excellent.
    You can spend over a £100 but are very unlikly to get better reception.
  4. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    i need to know the whole thing.
    all i know is invacom and syntec plat'2000.(singles&twin)
    which is better?
    what does bird mean?
    which size dish would best go with these lnb's
    what does horn mean?
    if it means fitting for the lnb to the dish,are they common?
    i just want the best lnb for sky,sky+ to give the best possible picture
    thank you
