Quantcast
Whats the best free HCPC SOFTWEAR
SLIM
Hi guys as you sean i bean posting a lot on the HCPC forum
As you may know im looking to set one up ASAP what i wont to know is whats the best Softwear to use and what plugins should i be looking for any help with this guys would go a long way.
Its ok reading stuff on thenet but its not the same as guys'girls that have them and use them all the time so any help thanks :smashin:
CrispyXUK
myHTPC
uczmeg
I'm looking at myHTPC and Xlobby at the moment and to be honest Xlobby is looking the more flexible and has built in pocket PC support so I'm going with that...
CrispyXUK
ok;
myHPTC for remote.
Xlobby only if you are using touchscreen or mouse
