what's the best converter scart to component or scart to s-video?
Discussion in 'Cables & Switches' started by music, May 5, 2005.
  1. music
    music
    Mar 25, 2005
    518
    +14
    coming out of my sky pace bax is an rgb scart which I want to run to yamaha DSP 750SE amplifier. Has component in and s-video in. Aiming for component out to plasma. Which is the best conversion method? Scart to component or scart to s-video?
    Thanks for any opinions.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,744
    The Borders
    +3,085
    music
    Assuming your Plasma Display or TV is equipped with YUV 'Component' Inputs then converting SCART RGB to YUV 'Component' is the better of the two conversions your considering.
    If your Plasma Display or TV is equipped with SCART sockets and they are RGB enabled then your possibly better going direct to the Display (SCART to SCART) and not via the AV Receiver or any form of converter.
    If you do go with an RGB2YUV solution and then switch via your AV Receiver you need to ensure the YUV Inputs on your Plasma Display or TV are compatible with an Interlaced PAL signal 576i(50) - most are these days but best not to assume anything as you don't mention which Display you have.
    Best regards
    Joe
