what's the best connection?
Discussion in 'Projectors, Screens & Video Processors' started by Ewan154, Mar 11, 2006.
  1. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    Hi!
    At the moment I have connected my DVD player to my PJ via scart. Would I get a better picture if I s-video to connect the dvd player to the PJ
    Any suggestions pls?
  2. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    Scart is generally recognised as being a superior connection to s-Video. Then Component and DVI/HDMI (although some argue Component is better than HDMI...)
  3. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    Thanks:thumbsup:
  4. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    +1,635
    It is worth checking that your DVD player and TV support RGB Scart as this is noticeably better. If they do both support RGB, make sure you use the right scart input on the TV and that your DVD player has Scart Video output set to RGB.
    Should make a difference :thumbsup:
  5. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    Hi!
    Thanks for the adivce:thumbsup: I have just set it to RGB and it has make a big difference:thumbsup:
  6. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    +1,635
    Cool, glad i could help ;)
